Product A-Z
  1. A
  2. B
  3. C
  4. D
  5. E
  6. F
  7. G
  8. H
  9. I
  10. J
  11. K
  12. L
  13. M
  14. N
  15. O
  16. P
  17. Q
  18. R
  19. S
  20. T
  21. U
  22. V
  23. W
  24. X
  25. Y
  26. Z
    A
  1. A
    Advanced Video Solutions
    Advantech offers a broad portfolio of hardware acceleration products supporting low latency 4K 8K HEVC to help address t... more
    All-in-one Service Touch Computers
    Advantech UTC series are 10-42” industrial-grade, fanless all-in-one touch computers, equipped with latest Intel� proces... more
    Automation Controllers & I/Os
    Evolved from traditional programmable logic controllers, Advantech’s programmable automation controllers (PAC) APAX seri... more
  2. B
  3. B
    Barcode Scanner
    Barcode Scanner
    Barcode exists in our daily life. A barcode reader (or barcode scanner) is an electronic device that can read and output... more
    Building Automation Systems
    As part of Building Management system, Advantech Building Automation systems helps intelligent buildings to increase ene... more
  4. C
  5. C
    Certified Solutions
    Certified Solutions
    Advantech has several certified products for the railway automation or power & energy automation, such as Det Norske Ver... more
    Class I, Division 2 Solution
    Class I, Division2 remote I/Os, such as CID1 monitors and CID2 solutions, have met the requirements of hazardous area co... more
    Computer On Modules
    Computer On Modules
    Computer-On-Module, or COM, is a development board with computer processor, chipset, memory, and peripherals designed in... more
    Cooler
    Cooler
    Cool your PC efficiently with Advantech WIN CPU cooler series! We offer active and passive CPU coolers adopting low nois... more
    CPCI & VPX Blades & Boards
    Advantech offers a complete range of 3U and 6U products, including CPCI CPU boards, CPCI chassis, and blade server for C... more
    CPU
    CPU
    Advantech offers wide selection of Intel processors (CPU) in most series and generations for every usage, including ente... more
  6. D
  7. D
    Display
    Display
    We offer wide selection of Industrial Displays based on all sorts of required applications and vertical markets, includi... more
    DRAM Memory Module
    DRAM Memory Module
    Choose the perfect memory solution for your application with Advantech! We offer a full range of industrial-grade RAM me... more
  8. E
  9. E
    Embedded IoT Solutions
    Advantech develops a series of integrated IoT solutions from sensor nodes, gateway to cloud and services to assist custo... more
    Embedded Software
    Embedded Software
    Advantech Embedded Software provides different solutions to ensure your IoT security, including backup cloud solutions, ... more
    Ethernet / Serial Device servers
    Advantech's serial device servers, Modbus gateways, and USB device servers are easy to install and configure. They also ... more
  10. F
  11. F
  12. G
  13. G
  14. H
  15. H
    Hard Drive
    Hard Drive
    Boost your PC storage with Advantech certified Hard Disk Drives (HDD), designed specifically for intensive use in Genera... more
    Healthcare Infotainment Terminal
    Advantech all-in-one healthcare infotainment is an intelligent bedside terminal for healthcare. The all-in-one bedside t... more
    Human Machine Interfaces
    Advantech HMI series contains high-performance panel PC, low-power industrial thin clients, web terminals for smart fact... more
  16. I
  17. I
    Industrial Computer Chassis
    Industrial Computer Chassis series offer IPC chassis, ATX chassis, IPC enclosure for Servers, Server Boards, Server Chas... more
    Industrial Computer Peripherals
    Advantech IPC peripherals can integrate with various modules including IPMI, TPM, power supplies and, with the versatile... more
    Industrial Flash & Memory Solutions
    Advantech Industrial Flash and Memory Solutions include: storage module, memory module and embedded I/O module. The SQFl... more
    Industrial Mobile Computers
    Advantech industrial mobile computing solutions applied in mobile resource management, such as fleet management, warehou... more
    Industrial Motherboards
    Advantech industrial motherboard series, ranging from Mini-ITX motherboard, Micro ATX motherboard to ITX motherboards, a... more
    Industrial ATX Motherboard is a standard form factor allowing customers to seamlessly upgrade without compatibility issu... more
    Industrial Portable Computers
    Advantech Industrial Portable Computers are the best mobile devices with integrated add-ons such as RFID and barcode sca... more
    Industrial Protocol Gateways
    Our industrial Fieldbus gateways provide seamless communication between Fieldbus and industrial Ethernet devices as well... more
    Industrial Servers & Storage
    Industrial server and storage series include multiple server rack and custom servers to ensure reliability, capacity exp... more
    Industrial Wireless and Gateway
    Advantech's industrial wireless solutions provide invaluable wireless infrastructure for your WLAN, covering affordable,... more
    Intelligent Connectivity Software
    Advantech intelligent connectivity software platform provides provisioning and management software, aiming at serving us... more
    Intelligent Power System
    Advantech’s iPS intelligent power system, with the latest industrial-grade and hot-swappable Lithium-ion battery, provid... more
    The Intelligent Transportation System support railway automatic fare collection, railway signaling, rolling stock, stati... more
    Intelligent Video Platforms
    Intelligent video solution includes video capture board to intelligent video system analytics (IVA) and Software Develop... more
    IP Camera
    IP Camera
    IP Cameras are widely used for surveillance and security purposes. Applications include Retail Store Security Surveillan... more
  18. K
  19. K
    Keyboard
    Keyboard
    Keyboards are essential to interfacing with computers. Advantech offers series specifically for general PC use with comp... more
  20. M
  21. M
    Machine Automation
    Machine Automation
    Advantech Machine Automation offers application ready platform for various automation control solutions such as motion c... more
    Medical Carts
    Medical Carts
    AMiS medical carts are mobile carts designed to optimize point-of-care service and patient care. Equipped with workstati... more
    Medical Computers
    Medical Computers
    Advantech offers a fanless medical computer series with medical safety certifications of UL60601-1, EN60601-1, and IEC60... more
    Medical Computing Platforms
    The Advantech Design & Manufacturing Services Medical Computing team provides a wide range of certified medical computin... more
    Medical Monitor
    Medical Monitor
    Advantech Kostec provides ultimate quality images for endoscopic and surgical image systems with its full product line f... more
    Medical Tablets
    Medical Tablets
    Advantech Medical tablets are equipped with LiFePO4 battery to support mobile computing in Mobile Clinical Assistant (MC... more
    Mobile Computing Platforms
    The Advantech Mobile Computing team offers industrial grade mobile computing devices including industrial tablet PCs and... more
    Mobile POS Tablets
    Mobile POS Tablets
    Advantech mobile POS tablets support diverse applications,such as self-ordering, shopping assistance and inventory manag... more
    Modular IPC
    Modular IPC
    The modular computers aim at machine automation applications such as vision inspection, AOI, packaging inspection and in... more
    Mouse
    Mouse
    Mice are essential to interfacing with computers. Advantech introduces series of Mice for Industrial and Medical applica... more
  22. N
  23. N
    Network Card
    Network Card
    Expand your network performance with Advantech Certified Industrial Grade Network Card, also called NIC (Network Interfa... more
  24. O
  25. O
    Optical Drive
    Optical Drive
    Optical Storage is made possible by data storage devices such as optical discs and holographic storage systems. This is ... more
  26. P
  27. P
    Panel PC
    Panel PC
    Panel PC product portfolio include customizable and all-in-one touchscreen pc series with multiple touch panel sizes and... more
    Point of Service Terminals
    With full range of POS products, Advantech offers retail POS solutions for both vertical market and OEM/ODM demand. High... more
    Power Supply
    Power Supply
    Stable and reliable power input for your valuable system with Advantech! We offer a comprehansive selection of high effi... more
  28. R
  29. R
    Rackmount Kit
    Rackmount Kit
    Advantech offers input devices including KBM (Keyboard & Mouse) and KVM (Keybaord, Video Monitor, Mouse) for commercial ... more
    RISC Computing Platforms
    We provided ARM-based computer-on-modules (RTX, SMARC and Qseven), 2.5" & 3.5" single board computers and box computers,... more
    Rugged Computing Platforms
    The Advantech Design & Manufacturing Services Embedded Computing team provides a wide range of rugged computing platform... more
  30. S
  31. S
    Semi-Industrial Motherboards
    Advantech Semi-industrial Motherboards (SIMB) include MicroATX, Mini-ITX, and ATX motherboards which offer cost effectiv... more
    Serial Converters, Isolators and repeaters
    To keep your serial equipment communicating and smoothly integrated with new technologies, B B SmartWorx has developed t... more
    Slot SBC & Backplanes
    Slot Single board computer (SBC) and backplane follows PICMG 1.0 and PICMG 1.3 standard that achieve flexibility and per... more
    Solid State Drive
    Solid State Drive
    Give your device a performance and storage boost with Advantech Certified Industrial Grade Solid State Drive (SSD)! SSDs... more
  32. T
  33. T
    Thermal Printer
    Thermal Printer
    A thermal printer is a digital printing device that uses heat to transfer an impression onto paper. Thermal printers can... more
  34. U
  35. U
    USB converters, Isolators and Hubs
    B B SmartWorx powered by Advantech USB products provide plug and play convenience with industrial ruggedness. Look for t... more
    UShop Solutions
    UShop Solutions
    Advantech UShop+ is a cloud platform built for retailers. We provide sales insight with business intelligence through mu... more
  36. W
  37. W
    WebAccess Software & Edge SRP
    WebAccess, as the core of Advantech’s IoT solution, is the first Client/Server/Browser based configurable SCADA software... more
    Wireless Sensing Solutions
    Wireless sensing technology delivers the data you need to manage and optimize your operations. Regardless of your indust... more
