Optimizing Uptime and Environmental Control with Advantech’s LoRaWAN Monitoring Solutions
应用案例 2025/6/10
Discover how Advantech Optimize Uptime and Environmental Control with Advantech’s LoRaWAN Monitoring Solutions
In data centers, facility and environmental monitoring plays a critical role in protecting IT infrastructure, maintaining safe operating conditions, and ensuring long-term reliability. Key infrastructure such as CRAC units, server racks, water pumps, fan motors, ceiling or raised floor structures, and VFDs must be monitored for electrical load, ambient temperature, humidity, and potential water intrusion. Integrating wireless monitoring into DCIM enables real-time visibility, faster response, and scalable facility management.
Common Challenges in Facility & Environment Monitoring
  • Limited visibility into distributed infrastructure conditions
  • Manual inspections delay detection of environmental risks
  • Complex wiring requirements increase deployment and expansion costs
  • Lack of integration with central facility management platforms
  • Difficulty identifying issues like overheating, leakage, or abnormal current draw before damage occurs
Application Concept
  • WISE-6610 V2: Industrial LoRaWAN gateway for aggregating and transmitting sensor data to central platforms
  • EVA-2210: LoRaWAN 3-phase current meter for monitoring electrical load and detecting abnormal power consumption
  • EVA-2311: Probe-type temperature sensor (PT1000) for high-accuracy equipment temperature monitoring
  • EVA-2310: Combined temperature and humidity sensor for ambient condition monitoring
  • EVA-2510: Leakage sensor for real-time detection of water ingress near critical equipment
System Architecture Overview
This solution deploys a comprehensive set of LoRaWAN-enabled sensors to capture electrical and environmental data across the facility. EVA-2210 tracks three-phase current usage for early power anomaly detection. EVA-2311 and EVA-2310 monitor both localized equipment heat and general room temperature/humidity. EVA-2510 identifies water leakage risks in vulnerable areas. All data is wirelessly transmitted to the WISE-6610 gateway, which forwards information to the central dashboard for live monitoring, alarms, and historical analysis. The wireless design supports flexible sensor placement and easy system expansion.
Key Benefits
  • Real-time monitoring of current, temperature, humidity, and leakage across the facility
  • Early risk detection and alerting to reduce downtime and prevent asset damage
  •  Simplified deployment and reconfiguration with wireless infrastructure
  • Historical data logging to support audits, compliance, and maintenance planning
  • Scalable architecture that grows with facility expansion
Adopting a wireless facility and environment monitoring solution enables data centers to enhance operational awareness, minimize risk, and extend equipment life. With Advantech’s LoRaWAN-based architecture, operators can monitor critical infrastructure in real time, receive actionable alerts, and streamline management across distributed assets. This not only improves uptime and efficiency but also lays the foundation for scalable and intelligent data center operations.
