Streamlining Warehouse Picking Systems with Quick-Response Interfaces
2/3/2021
Project Introduction
Project Requirements
Slim, Light Design
IDS-3215 leverages a simplified mechanical structure, yielding a lightweight solution. The monitor architecture uses a 3 piece metal frame with a thickness of only 39.2 mm (1.54 in). This is much slimmer than competitors’ solutions, which are 50 mm (1.96 in) thick. Correspondingly, the majority of available touch screen solution re 3.5 kg (7.7 lb). Advantech’s IDS-3215 is only 2.6 kg (5.73 lb). This slim, lightweight design improves installation efficiency.
Ruggedized and Reliable Design
Advantech IDS-3215P monitor met our customer’s requirements perfectly. The backlight brightness of 500 nits facilitated excellent image performance in indoor environments.
The 15” rugged panel mount monitor utilizes a projective capacitive touch solution to ensure quick response times and smooth operation.
