Advantech UNO-258 Leads the Way on Industrial Automation
17-09-2026
Real-time AI applications at the Edge are the leading drivers of innovation for industrial automation and manufacturing in the smart factories of today and tomorrow.
These systems require low latency at unprecedented levels, while still offering peak processing performance to accomplish AI-enabled tasks in machine vision, robotics, and other smart manufacturing requirements. What’s more, they need to be stable, reliable, resilient, and robust under even extreme conditions of high temperatures, dusty, damp, and harsh environments.
The answer to all these critical concerns is rarely found in one solution, but Advantech has launched its newest Edge AI Box PC with exactly these challenges and their solutions in the design.
The UNO-258 is Advantech’s next-generation Edge AI PC, and it is designed to accelerate real-time AI applications in smart manufacturing, machine vision, and industrial automation. Its computing power is supplied by Intel’s Core Ultra Series 3 processors, and the system is capable of delivering up to 180 TOPS AI performance, according to Advantech, thanks to its integrated CPU, GPU, and NPU architecture. This enables the mission-critical low-latency AI inference directly at the edge that is required in smart factories.
As industrial environments increasingly demand real-time inspection and quality control systems, autonomous industrial operations, and AI-driven analytics and agents, traditional compute systems are beginning to show their limitations as they struggle with thermal constraints, unstable operation, and complex deployments.
Advantech is showing that UNO-258 can address these challenges. The edge AI computer features a rugged fanless design, wide-temperature operation, and industrial-grade reliability purpose built to withstand harsh environments. It has been designed with a compact form factor, but the platform still supports high-speed connectivity, multiple vision and industrial I/O interfaces, and flexible expansion capabilities, making it capable of the industrial automation tasks needed, including Vision AI, robotics, smart transportation, and edge applications.
As a leap forward from conventional industrial PCs, UNO-258 is able to combine vast AI computing performance, fanless heat management and durability, and simplified deployment into a compact edge-ready platform optimized for next-generation Edge AI workloads.
Take a look at the technical specs of the Edge AI Compact Box PC with its Intel Core Ultra Processors Series 3:
- Intel Core Ultra Series 3 processors with 25W and 45W TDP support
- Integrated AI acceleration providing up to 180 TOPS total AI performance (120 GPU + 50 NPU + 10 CPU)
- Xe3 GPU architecture providing up to 2× the graphics performance compared to Arrow Lake-H
- Dual-channel DDR5 SO-DIMM memory supporting up to 128GB (64GB per channel)
- M.2 E-Key, B-Key, M-Key (supports NVMe) expansion for storage, LTE/5G, and Wi-Fi
- Built-in 1000Mbps & 2500Mbps LAN ports with TCC and TSN support
- Modular I/O board design offering dual LAN or isolated DIO/CANBUS/COM
As the landscape of industrial manufacturing and supply chain evolves toward automation and smart operations, Edge AI PCs are going to be the way forward. And the power and resiliency of the Advantech UNO-258 Edge AI Compact Box PC with its Intel Core Ultra Processor (Series 3) is clearly leading the way.
Intel Edge Solution Builders Initiative
This blog is part of a series showcasing the Intel Edge Solution Builders program and the expanding Intel Edge AI ecosystem. By collaborating with software vendors, solution providers, system integrators, and industry innovators, Intel helps cultivate robust, industry-specific vertical ecosystems that accelerate AI adoption at the edge and enable organizations to realize tangible real-world business outcomes.
To further support ecosystem growth and collaboration, the Intel Solutions Hub serves as a central platform where partners can discover technologies, engage with ecosystem members, and showcase innovative solutions built on Intel technologies.
Explore Advantech solutions and real-world industry use cases in the Intel Edge AI Catalog, and discover how the ecosystem is driving the next generation of AI-powered edge deployments.
This article originally published on Embedded Computing Design. To learn more about the UNO-258, contact your local Advantech sales representative or visit the Advantech website at www.advantech.com.
