A Total Solution for Water Supply Plants
31-05-2012
Project Introduction
Product | Description |
APAX-5520KW |
PAC with KW SoftLogic |
APAX-5017 |
12-ch Analog Input Module |
APAX-5028 |
8-ch Analog Output Module |
APAX-5040 |
24-ch digital input module |
APAX-5046 |
24-ch digital output module |
EKI-1322 |
2-port RS-232/422/485 to GPRS Serial Device Server |
ADAM-4572 |
1-port Modbus/Rtu Gateway |
ADAM-4117 |
Robust 8-ch Analog Input Module |
EKI-7626C |
16+2G Combo Port Gigabit Unmanaged Industrial Ethernet Switch |
Although the entire water supply system is complicated, the customer no longer needs to worry about the system compatibility as the entire systems products are provided by Advantech to ensure the best performance. Certainly, the plant saves a lot of manpower and resources through this total solution.
