How can AI ensure safety and access control on manufacturing sites?
08-05-2026
In dynamic manufacturing environments where safety, traceability, and efficiency are critical, VisionSense combines AI-powered facial recognition with centralized access control to secure production zones, automate attendance tracking, and ensure every worker meets compliance standards before entering the line.
What's the challenge?
Construction environments face constant changes in personnel, suppliers, and locations. Managing who enters, ensuring certified workers, and keeping records compliant are daily operational challenges.
- Regulatory Pressure : Sites must comply with strict labor and safety standards, requiring accurate verification of every worker and visitor.
- High Workforce Turnover : Frequent contractor rotations make manual identity checks inconsistent and time-consuming.
- Disconnected Systems : Safety records, attendance logs, and access data often exist in silos, limiting real-time visibility.
- Temporary Deployment Needs : Projects relocate frequently, demanding quick setup and teardown of security systems.
Why it matters now?
As projects accelerate and regulations tighten, digitizing identity and safety workflows is no longer optional. Applying facial recognition and linking it with safety validation systems turns access management into a proactive control—blocking unqualified entrants, updating on-site headcounts instantly, and proving compliance with verifiable logs.How AI solves it?
AI transforms on-site safety management by connecting facial recognition, access control, and digital signage into one cohesive system. Each worker’s identity is verified automatically at the gate, their safety training status confirmed through the validation system, and attendance logged in real time. Managers gain full visibility across zones, while deployment remains flexible for temporary sites.
- Access Control & Safety Verification : Facial recognition terminals confirm worker identity and certification before entry.
- Real-Time Attendance Monitoring : Entry and exit events are instantly recorded, with live headcount displayed on-site dashboards.
- Centralized Oversight : VisionSense Manager aggregates profiles, synchronizes safety validation data, and issues notifications when irregularities occur.
- Portable & Rapid Deployment : Modular edge devices and plug-and-play gateways allow quick setup, relocation, and reuse for new projects.
How it works?
VisionSense combines PPE detection, identity validation, and automated gate control into a unified workflow. Edge AI analyzes camera feeds in real time, the VisionSense Manager verifies profiles and safety compliance, and a relay module triggers gates only when workers meet all requirements.
- Video Input — IP Camera : Cameras positioned at the entry gate stream RTSP video to monitor workers approaching the checkpoint. The system captures facial data and checks whether required PPE (e.g., helmet, vest) is worn correctly.
- VisionSense Edge — Solution Ready Package : Performs on-device AI inference on live video to provide facial analysis. It also handles API events related to facial recognition data.
- Centralized Control — VisionSense Manager : Syncs worker profiles, updates attendance records, and confirms PPE compliance. If all conditions are satisfied, the Manager sends approval to the relay module.
- Automation — ADAM-6066 Relay to Gate : The relay module receives the verification signal and automatically opens the gate, ensuring only compliant and authorized workers enter restricted factory zones.
- Optional — Access Control Tablet : Used for dual-verification, displaying worker info, or manual override when needed.
| Requirement Device |
| Optional Device |
This integrated workflow ensures that only properly equipped, authorized workers can enter production areas—combining real-time PPE detection, identity verification, and automated gate control for a safer, more compliant manufacturing environment.
Where it scales next?
As construction operations digitize, the same AI infrastructure extends beyond access control — supporting safety compliance, subcontractor coordination, and cross-site visibility for enterprise-scale deployment.
| Application |
Function |
Benefit |
| Subcontractor Portal |
Pre-register workers and upload safety credentials before site entry. |
Streamlines onboarding and minimizes gate congestion. |
| PPE Compliance |
Detect safety helmets and vests through AI vision at access points. |
Prevents violations and enhances workplace safety from the start. |
| Multi-Site Dashboard |
Aggregate headcount, incident data, and compliance rates across all projects. |
Enables proactive audits and smarter resource allocation. |
Together, these extensions evolve site access control into a comprehensive, data-driven safety management ecosystem—portable between projects and governed from a single platform.
FAQ
1. Can the system recognize workers while they are wearing safety masks or helmets on the production line?
Yes. The algorithm supports partial facial feature extraction and can accurately identify individuals even with safety masks and helmets.
2. Can the recognition device work properly in factory zones with low illumination or at night shifts?
Yes. Requires cameras with infrared or night vision support for optimal performance under dark conditions.
3. When safety violations or abnormal worker behaviors are detected, does the system send real-time alerts to managers?
Yes. Instant alerts can be sent to mobile devices and can trigger external devices such as alarms or signal lights.
4. Can the recognition device analyze worker behaviors, such as unsafe movements or improper operations?
Yes. Supports behavior analysis such as unsafe movement detection, PPE compliance checks, and restricted-area access monitoring.
5. How to manage VisionSense Edge remotely and connect to VisionSense Manager when deployed behind NAT/firewalls or across multiple local networks?
In most cases, you only need to allow VisionSense Edge to initiate outbound connections. Edge communicates with external systems, such as remote administrators or the VisionSense Manager, by establishing outgoing connections. Please ensure the following ports are allowed for outbound (LAN → WAN) traffic:
| Port |
Purpose |
| 59000 / 59001 / 60001 |
System service management |
| 6075 / 6089 / 6090 |
AI and video services |
| 3161 |
Internal communication |
| 80 / 443 |
Web services (HTTP/HTTPS) |
6. Where does the system originate from?
The entire system is designed and developed in Taiwan.
Contact Us
Advantech is dedicated to supporting your company to build a safe environment and increase management efficiency. Our experts are here to guide you through each step of implementing effective, sustainable solutions. Please reach out to our team at Contact Us.
Join our community to see more industry insight:
