IOTech Edge Connect™ Software and Advantech Hardware Speeds Adoption of IIoT Technologies
28.10.2023
Factory and process manufacturers are embracing industrial Internet of Things (IIoT) and edge compute solutions to help access and optimize data between operational equipment and control systems. These systems need to reliably aggregate data from many sources, but managing numerous endpoints, such as industrial sensors, machinery, PLCs (to name a few) can be challenging.
Ideal for systems integrators (SIs) and original equipment manufacturers (OEMs), IOTech and Advantech developed a new range of integrated edge hardware + software solutions to address these data challenges.
Incorporating IOTech Edge Connect™ plug-and-play edge software and Advantech IoT edge gateways and high-performance IPCs, the edge bundle provides base infrastructure for autonomous decision-making and real-time asset/process monitoring, and creates unified networks and systems through vertical and horizontal integration.
Data Connectivity & Edge Processing Solutions
The combined IOTech + Advantech solutions address the following commercial and technical challenges:
- Cuts down technology complexities, which may require costly integration
- Leverages latest advances in edge computing and Industry 4.0 standards
- Alleviates system siloes that are difficult to maintain and costly to evolve
- Acquires data from copious data points in real-time with low latency
- Aggregates plant data from multiple sources, offering application visualization of data
- Supports both Greenfield and Brownfield sites and equipment
- Helps integrate SCADA/Cloud/IT systems for remote management and access, with reliable security
The IOTech Edge Connect software solution enables users to create data-driven industrial applications, add rule based event detection/reaction, integrate data dashboards, and leverage advances in artificial intelligence (AI), analytics, and inferencing technologies.
In combination with Advantech industrially-designed hardware, IOTech Edge Connect provides comprehensive, multi-protocol OT connectivity for numerous industrial standards. With simplified “no code” connectivity and device onboarding, the solution is also user-friendly, offering tools and device discovery features.
Edge Hardware Solutions for Versatile Functionality
UNO-2271G-V2 Intel-based Edge Gateway
Intel® Celeron® Dual core N6210/ Pentium® Quad core N6415 processor
MIC-770 V2 Intel-based Embedded IPC
Intel® 10th Gen Xeon®/Core™ i CPU socket-type (LGA1200) with Intel® W480E/H420E chipset
ECU-150 High-Performance IoT Gateway
NXP i.MX8M Quad Core Cortex A53 1.3G CPU
Initial use cases include applications in: Discrete and Process Manufacturing, Oil and Gas, Energy and Utilities, Water, Building Automation, Smart Cities, Transportation, Maritime, Retail, and more.
Learn More
The edge appliances are available for purchase from Advantech as well as through select distributors, such as TD SYNNEX (solutionsaggregation@tdsynnex.com). The scalable solution is available in a variety of form factors and price points to suit specific needs, including cost-effective options for real-time industrial data acquisition and aggregation.
To learn more, visit the IOTech website at https://www.iotechsys.com/.
