Learning Advantech LoRa Sensing Technology for Intelligent Building Management Systems
1/22/2018
Market: Intelligent building management Industrial
Application: Wireless sensing and remote management
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1575310174653.jpg)
Project Intention
Challenges and Requirements
Solution
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1553086821668.png)
The procdure is outlined as follows:
Features, Advantages, and Benefits
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871105634.png)
LoRa Wireless Network Technology
The LoRa platforms provide wireless long-range network communication functionality without the need to pay telecommunication fees, which can have a marked impact on reducing network operating costs. Furthermore, traditional wireless solutions (e.g., access points) have a limited data transmission range and thus force users to adopt an intensive approach to node deployment. Even though cellular routers are unaffected by such problems, they still require the user to pay telecommunication fees.
3AI/1DI for Multiple Sensors and Customized Software
The LoRa Private Node can connect up to four sensors simultaneously, making it especially ideal for production lines that have many sensors or for applications where there is limited space for additional devices. Furthermore, the software for Advantech’s LoRa products can be customized to accommodate the most sophisticated of monitoring plans. Because the Wzzard LoRa Private Node offers a high level of flexibility in both hardware and software aspects, it frees users from having to deploy an infrastructure-heavy wireless network, meaning that resources can be allocated to other more critical investments. IP66 Enclosure and Battery/Solar Design for Remote Outdoor Sites
With an IP66 rating, the Wzzard LRPv Node and SmartSwarm 243 Gateway are protected against ingress by and contact with dust as well as powerful water jets. The dual-power design of these devices (DC/battery for the Wzzard LRPv Node and solar/battery for the SmartSwarm 243 Gateway) also gives users multiple deployment options.
Dual Power-Saving Modes and an Alarm System
The LoRa Private Node has two power-saving modes: sleep mode (for when the node is not in use) and operation mode (for scheduled data transmissions). For instance, if a node were scheduled to report sensor data twice per hour, then sleep mode would automatically activate when the node is not in use, and operation mode would wake the node when the data must be transmitted, thus maximizing the energy efficiency of the device. An alarm system is also installed to notify users when a particular value has exceeded a given threshold.Why Advantech?
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1553086830348.jpg)
Product Information
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1553086834384.png)
More to Read
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516872025064.jpg)
For remote areas and harsh environments, Wzzard LRPv sensor nodes and gateways are user-oriented and designed to meet your intelligent infrastructure needs. The Wzzard LRPv series provides a reliably secure network with almost no wiring and little maintenance effort. This allows you to easily monitor remote sensors in any environment from your desk.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871878799.jpg)
These devices can be deployed in both flood monitoring areas and control rooms to achieve flood forecasting and early disaster.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871866958.jpg)
Advantech’s Wzzard LRPv Node and SmartSwarm 243 Gateway can facilitate minimizing irrigation water wastage by utilizing LoRa technology to build an efficient, cost-saving system.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871856241.jpg)
The LoRa solution can facilitate improving overall equipment effectiveness (OEE) by utilizing LoRa technology to build a reliable system for monitoring the condition of machines.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871840954.jpg)
Advantech Fieldbus gateways bring seamless conversion between individual industrial protocols and allow the connection of devices with different protocols for diagnosis, analysis, and management.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871811366.jpg)
By collecting production line operation status and machine condition data in its Taoyuan campus, NYP can enhance its overall equipment effectiveness and shorten its time to market.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516871800314.jpg)
By implementing Advantech solution, managers can migrate seamlessly from traditional to future network infrastructure with minimum downtime and maximum flexibility.
![](https://advcloudfiles.advantech.com/cms/9ed93963-0788-4966-abcd-e5fa981841e5/Content/content-image-1516872067802.jpg)
Management at the company’s compressor manufacturing plant sought to implement a remote monitoring system to accommodate rapid growth in business scale and the number of machines/sensors at the plant.
