This how-to article describes the process of building and installing Windows 10 IoT BSP on the Advantech RSB-3720. Check out our developer article to guide you step-by-step to set up Windows 10 on Arm.
.jpg)
Advantech has placed board support packages (BSP) on RSB-3720 with i.MX 8M Plus series application processor platforms to support Windows 10 IoT Enterprise. This highly-optimized Windows 10 IoT BSP makes it easier to build secure and scalable solutions from device to cloud, and supports diverse functions to provision, manage, and secure devices at scale. Meanwhile, this enables developers to use preexisting and familiar app development frameworks like .NET Framework, .NET Core, WinForms, and WPF; in addition to more modern frameworks like UWP and WinUI. Furthermore, Advantech has packed a powerful combination of I/O and peripherals into RSB-3720 buttressing the i.MX 8M Plus processor to produce a solution adaptable to diverse requirements. The small footprint of the RSB-3720 results in a cost-effective and lower power solution that enables developers to build new, compact, and fan-less Windows IoT devices in form factors not previously possible.
This how-to article describes the process of building and installing Windows 10 IoT BSP on the Advantech RSB-3720. Check out our developer article to guide you step-by-step to set up WoA. Alternatively, join the conversation and discuss Arm-based computing solutions in our AIM-Linux Community.
-50/ROM-3620_3D-_Banner20201203172950.jpg)
-50/ROM-5722_3D--_Banner20210416091443.jpg)
