Preventing Production Line Jams At Baked Goods Factory
29/12/2019
Challenge
Production at a large baked goods manufacturer was nearly "toast". The numerous baked goods products used numerous pan sizes. A constant-speed conveyor system caused major headaches with pan jams and inconsistent conveying rates into the bun cooler and bagging lines. The company needed a quick and economical way to smooth out the lumps and implement intelligent control. The conveyor system utilized RS-485 communications, was nowhere near its end-of-life and represented a huge capital investment. Replacement was out of the question.
Solution
Luckily, the company’s system integrator had recently learned about Advantechs’ data communication devices. Connecting an optically isolated serial converter from Advantech, a touch panel and PLC was easy. Now, the oven discharge conveyors and de-panning of bread products can be monitored and controlled automatically. The company preserved its legacy equipment investment and increased plant floor productivity at the same time. And, the “dough” is rolling again…
Features & Benefits
  • Converts RS-232 data to RS-485 data
  • 2000 V, 2-way isolation on input and output
  • 115.2 kbps data rate; extends data up to 1.2km
  • Wide temperature range: -40 to +80 °C
  • DIN rail mount10-30 VDC operation
  • FCC, uULus Recognized, CE, NEMA TS2
  • RS-232 connects to DB9 or terminal block
  • RS-422/485 connects to terminal block
  • LED indicators for RD, TD, Power
  • Modbus ASCII / RTU compatible
  • Automatic Send Data Control
Why Advantech
For price-for-performance value, choose serial converters from Advantech - RS-232/422/485, TTL, current loop, baud rate, Allen-Bradley™, fiber optic and more. Designing, customizing, and manufacturing rugged and reliable products, Advantech provides IoT, M2M, industrial automation and device networking solutions. Whatever data protocol you need to convert, we can help you, too.
