The Claxon Family
กรณีศึกษา 04/29/2024
CoaXPress Version 2.0 doubles the speed of CXP up to 12.5 Gb/S. Advantech stays ahead of the curve with its Claxon frame grabber family that supports up to four links of CXP-12 and all of the new CXP 2.0 features.
Introducing The Claxon Platform
Advantech's Claxon family, available as a single, dual or quad CXP-12 PCIe frame grabber. CXP-12 is the latest CoaXPress speed jump, now transmitting video at 12.5 Gb/S. While the speed of data through the frame grabber has doubled, the overall architecture has remained the same as the previous generation Cyton, allowing users to easily migrate to the newer cameras without major software changes.
CoaXPress
CoaXPress (CXP) is the latest Machine Vision designed camera to frame grabber intercon nect standard. CXP supports a high speed downlink for video data, a low speed uplink for camera control, and power, all over standard coaxial cables. Multiple CXP connections can be aggregated to even higher speed cameras.
CXP 2.0 not only doubles the speed from the previous release (6.25 to 12.5 Gb/S) but also adds many new features directed at industrial Machine Vision. For example, the uplink is now running twice as fast, and the trigger packet has been simplified to support much higher cam era trigger speeds. Support has been added for device to host event packet, supporting asynchronous messages from the camera. Also added was support for the micro BNC connector which is more robust and runs at higher speeds than the DIN 1.0/2.3. A heart beat packet has also been added which supports time synchronization of multiple cameras.
Application Support
Adding the Claxon-CXP to your application is simple with our SDK, which supports both 32-bit and 64-bit operating systems. Applications can be developed using C/C++/C# and our sophisticated buffer management APIs. In addition, free drivers can be download from our web site for most 3rd party machine vision packages. The Claxon-CXP is software compatible with all the other current Advantech BitFlow frame grabbers. This makes migrating applications from Camera Link or analog to CXP simple and quick.
Flexible Camera Support
The three Claxon model cover most maching vision application, from a single low cost CXP-12 camera, to a monster quad CXP-12 beast, as well as multi-camera applications. For example, the Claxon CXP4 can handle four single link CXP-12 cameras.
The Claxon-CXP Features
  • Half size x8 PCI Express Gen 3.0 frame grabber
  • The Claxon-CXP1 is quarter size PCIe
  • The Claxon-CXP1 is optionally available with a low profile bracket
  • CoaXPress 1.0/1.1/2.0 compliant • Supports one to four CXP-12 cameras
  • Supports multi-link CXP-12 cameras (up to four CXP links)
  • No firmware change needed to go from multi-link cameras to multiple cameras
  • Supports CXP speeds from 3.25 to 12.50 Gb/S
  • Low speed uplink supported on all links
  • Uses micro BNC connectors
  • Provides power for all cameras (up to 13 Watts per link)
  • Provides Safe Power, full protection from all power line faults
  • Cameras are Plug and Play with automatic link speed and camera parameter detection
  • Cameras can be accurately synchronized, or can be com pletely independent
  • Compatible with all PCIe x8/x16 slots Gen 1.0/2.0/3.0
  • Separate I/O for each camera • Highly deterministic, low latency uplink camera trigger
  • Windows “sees” a separate virtual frame grabber for each camera
  • StreamSync technology maximizes data through-put while minimizing image latency • Acquire variable length frames from line scan cameras
  • Triggers and encoders for external control of acquisition
  • Drivers, utilities and examples for Windows and Linux • Supported on both 32-bit and 64-bit platforms
  • Drivers for most 3rd party processing environments (e.g. HALCON, LabView, VisionPro, MATLAB, etc.)
  • Full GenICam support for camera control and capture
  • Programmable signal generator for camera control (inde pendent for each camera)
  • Quadrature encoder support including sophisticated trig gering schemes
  • Encoder divider/multiplier • RoHS compliant
ติดต่อ Advantech
