Enhancing Data Center Cooling Stability with Proactive LoRaWAN Monitoring Solution
ケーススタディ 06/10/2025
Discover how Advantech helps Data Center Cooling Stability with Proactive LoRaWAN Monitoring Solution
In data centers, cooling systems are essential for maintaining optimal temperatures and preventing thermal overload of IT equipment. Adopting LoRaWAN wireless technology enables real-time vibration and I/O monitoring, delivering predictive maintenance, operational flexibility, and enhanced visibility, making cooling systems smarter, more reliable, and easier to manage.
Common Challenges in Cooling System Monitoring
  • Manual inspections lead to delayed response and increased maintenance costs
  • Mechanical wear in pumps or fans often goes undetected until failure occurs
  • Wired systems are costly and difficult to deploy in large-scale or retrofit scenarios
  • Lack of centralized visibility across distributed cooling assets
  • Difficulty integrating multi-source data into BMS or cloud dashboards
Application Concept
  • WISE-6610P: Industrial outdoor LoRaWAN gateway that aggregates wireless data from field sensors
  • WISE-2410X: LoRaWAN vibration sensor for real-time monitoring of fan and pump vibration levels
  • WISE-4610P + WISE-S617-A: LoRaWAN I/O module collecting analog/digital signals such as temperature, flow rate, and alarm status
System Architecture Overview
The system architecture includes LoRaWAN vibration sensors installed on cooling tower fans and pumps to monitor vibration data and detect anomalies. I/O modules connect to temperature sensors, flow meters, and alarm relays for additional data collection. All sensor data is transmitted wirelessly via the WISE-6610P gateway to a central platform. This solution enables real-time monitoring, remote diagnostics, and automated alerts for abnormal conditions. Integration with the facility’s management system or a cloud dashboard provides a holistic view of cooling system health and operational efficiency.
Key Benefits
  • Wireless deployment simplifies installation and reduces cabling costs
  • Real-time vibration and I/O monitoring enables predictive maintenance
  • Early fault detection minimizes unexpected downtime
  • Scalable solution supports monitoring across large or expanding facilities
  • Integration-ready with BMS and cloud dashboards for centralized control
  • Enhances operational visibility and cooling system performance
With Advantech’s LoRaWAN-based vibration and I/O monitoring solution, data centers can ensure more reliable and efficient cooling system operations. From early fault detection to centralized asset management, this wireless architecture offers a smart, scalable, and cost-effective approach for modern data center environments.
アドバンテックへのお問い合わせ
