Advantech Edge AI System Application Cases - AI in Healthcare
적용사례 09/20/2024
Bringing AI to The Edge - Advantech Edge AI System Application Cases
Case 1 - Connector Manufacturers Use AI to Improve Quality and Efficiency
  • AI inspection in mass production provide efficient inspection results.
  • Undetected defects of less than 1% and machine yield rate of more than 95%.
  • Shift manpower to other processes, reducing both production costs and potential labor shortage risks.
Case 2 - AI Images for Identifying Critical Production Bottlenecks
  • Replacing traditional stopwatches to manage production lines is much more efficient and easy to digitize.
  • AI dynamically helps adjust production line resources, optimizing on-site manpower allocation.
  • Complete visual records of each assembly operation can be kept and help improve future processes.
Case 3 - An AI Defect Detection System for Paper Jar Production
  • Performs better than human eyes to inspect up to 33 paper jars per second with accuracy rates surpassing 98%.
  • All in one platform simplified vision AI deployment time and space.
