Minimizing Defects with a Cold Chain Monitoring and Tracking Solution for Semiconductor Manufacturing
Estudos de Caso 07/28/2022
Advantech’s proposed solution provided the customer with customized embedded computing technology designed specifically for cold chain monitoring and tracking from the edge to the cloud.
A global semiconductor foundry that makes chips for other companies required a solution to control the quality of photoresist during logistics. The customer’s original system did not provide real-time status reports on key materials, resulting in serious manufacturing defects due to unforeseen problems with the quality of the manufacturing process, leading to huge losses. To overcome these problems, Advantech Design and Manufacturing Service provided a compact cold chain solution that enabled real-time monitoring and analysis of the temperature and humidity conditions affecting key materials.
The impact of low-quality photoresist
Maintaining photoresist quality is important in semiconductor manufacturing because low-quality photoresist interrupts the production process, and this has a considerable impact on business operations and profits across the entire semiconductor industry. The proper storage of the photoresist solution is thus critical to ensuring the quality of subsequent processes, as it ensures that production runs smoothly and product quality is high. This is why the real-time monitoring and analysis of the status of key materials in transit is critical.
Cold chain monitoring and tracking from the edge to the cloud
The present case required an open interconnection platform to monitor of the status of photoresist liquid. Built on Azure IoT Edge technology, Advantech’s proposed solution provided the customer with customized embedded computing technology designed specifically for cold chain monitoring and tracking from the edge to the cloud. Critical data in this case were temperature, humidity, battery life, gas, air pressure, location, and vibration data. These are stored locally in a log file that is uploaded to Azure via NB-IoT and MQTT, the timing of which is triggered by GPS/BeiDou/GLONASS data, thus making it more reliable when uploading material status information at key points during transportation.
This required a tracking device to be packed into each photoresist package, which adds to shipping costs. As such, a lightweight design was a critical consideration. Advantech’s proposed NB-IoT based cold chain sensor was not only compact and lightweight (>100 g; dimensions: 75 × 75 × 23 mm), but it extended the battery lifetime of the previous system from 14 to 30 days.
Real-time monitoring reduces defects and boosts production
Advantech’s extensive industrial expertise and comprehensive support services meant that they were able to offer customized services combined with advanced technology to effectively reduce the solution development time and costs. The proposed solution enabled real-time monitoring analysis of key materials, and this has contributed significantly to reducing the risk of material failure, which in turn has boosted production yield.
Explore Details
