MIC-733-AO Use Cases- AI Automatic Optic Inspection System
18.01.2023
Benefit
A solution which combines rule-based machine vision and AI visual identification is not only the perfect answer to a factory’s problems but also contributes to the introduction of automatic inspection systems.
Challenges
In the past, industrial PCs adopt NVIDIA GPU to achieve high computing of AI inference in AOI applications. However, PCs installed with GPU cards suffer a lot from heat dissipation, power consumption or even limited space. It is difficult to install the system into an equipment like a robot arm.
Solution
MIC-733-AO based on AGX Orin overcomes the issues and make AI AOI easy to be added into existing equipment with concern. Its high computing and rich I/O could handle video acquisition, AI inference and control command.
