Advantech’s Robust Industrial-Grade Switches Connect Devices and Machines for an Interconnected Network on the Shop Floor
Market: Factory AutomationLocation: TaiwanCustomer: Symtek Automation Asia
Project Introduction
- Barcode readers are used to scan items and obtain information from the ERP system.
- Robotic arms are employed to pick up items and place them on conveyors.
- Conveyors and motors are utilized to transport items via a conveyor belt to the lab where they are later assembled into finished goods by other machines.
- HMIs are used to view quality assurance results on finished products.
- AGVs and RGVs are employed to package and transfer finished products to the warehouse after they have passed a quality check.
- Each production line has its own cabinet and workstation. The cabinet aggregates all data to an ARK-3510/1550 fanless PC, a PLC, and an HMI, and relevant data are sent to an HPC-7442 data center. All communication is achieved via Ethernet.
- The ARK-3510/1550 receives material codes from the barcode scanners, and the material information is shown on the HMI.
- Operators can press a “confirm” button to trigger the PLCs to operate the robotic arms.
- By performing a diverse range of motions, the robotic arms pick up and place items on the conveyor. Once the material has been transferred to the specified location, the PLC triggers the next command to drive the motors. The material is then transferred to a lab and the finished product is assembled by other machines.
- After the entire assembly process and quality testing have been completed, all information, including the operating schedule, material list, and test results, are transmitted to the ARK-3510/1550 and HPC-7442.
- Finally, products that pass quality testing are packaged and transferred to the warehouse. For this, the PLC issues a final command to the AGV/RGV, which transports the products to the appropriate storage location, and the information is sent to the ERP system and HPC-7442.
- EKI-5525-AE: 5-port 10/100 Fast Ethernet Unmanaged Industrial Ethernet Switch
- EKI-5528-AE: 8-port 10/100 Fast Ethernet Unmanaged Industrial Ethernet Switch
- EKI-5526-AE: 16-port 10/100 Fast Ethernet Unmanaged Industrial Ethernet Switch
- ARK-3510L-00A1E: Fanless Box PC with 3rd Generation Intel® Core™ i3/i5/i7 and two 2.5" Removable HDD Bays
- ARK-1550-S6A1E: Slim and Panel Mountable Fanless Box PC with 4th Generation Intel® Celeron® 2980U SoC
- HPC-7442MB-00XE: 4U Rackmount Chassis for EATX/ATX/Micro-ATX Motherboard with Four Hot Swap Drive Trays
/EKI-5525SI_S20141105162559.png)
-50/ULI-342TC_02--20250416145820.png)
-50/EKI-2701PSI_03-20241226145130.png)
-50/ULI-224TC_01--20230907173404.jpg)
