Building a Wireless Remote Monitoring and Management System for China’s Leading Electrical Appliance Manufacturer
22/01/2018
Market: Factory automation Industrial
Application: Wireless remote monitoring management
Project Intention
Challenges and Requirements
Solution
The procedure is outlined as follows
Features, Advantages, and Benefits
- Link any serial device to an IEEE 802.11b/g/n network
- Supports IEEE 802.11n MIMO 2T2R
- WLAN transmission rate up to 300 Mbps
- Supports secure access with WEP, WPA/WPA2-Personal, WPA/WPA2- Enterprise
- Provides COM port redirection, TCP, UDP, and pair connection modes
- Supports up to 921.6 kbps and any baud rate
- Provides a Web-based configuration and Windows utility
Why Advantech?
Product Information
IEEE 802.11b/g/n network - Support 802.11n MIMO 2T2R
- WLAN transmision rate up to 300 Mbps
WPA/WPA2-Personal, WPA/WPA2-Enterprise - Provides COM port redirection, TCP, UDP,
and pair connection modes - Supports up to 921.6 kbps,
and any baud rate setting - Provides Web-based configuration
and Windows utility - Allows a max. of 5 hosts to access one serial port
- Supports 32-bit/64-bit Windows 2000/XP/Vista/7,
Windows Server 2003/2008, Windows CE 5.0, and Linux - Allows a max. of 4 hosts to be
accessed as TCP client mode
More to Read
By collecting production line operation status and machine condition data in its Taoyuan campus, NYP can enhance its overall equipment effectiveness and shorten its time to market.
By implementing Advantech solution, managers can migrate seamlessly from traditional to future network infrastructure with minimum downtime and maximum flexibility.
These devices can be deployed in both flood monitoring areas and control rooms to achieve flood forecasting and early disaster.
The LoRa solution can facilitate improving overall equipment effectiveness (OEE) by utilizing LoRa technology to build a reliable system for monitoring the condition of machines.
Advantech Fieldbus gateways bring seamless conversion between individual industrial protocols and allow the connection of devices with different protocols for diagnosis, analysis, and management.
Advantech’s Wzzard LRPv Node and SmartSwarm 243 Gateway can facilitate minimizing irrigation water wastage by utilizing LoRa technology to build an efficient, cost-saving system.
