Baud Rate Resistor - 485TBLED - RS-232 to RS-485 Converter
23/10/2018
With Model 485TBLED, the RS-485 driver will shut off approximately 1ms after the last character has been sent.
If you need to change the 485TBLED to a baud rate other than 9600 baud, you can change this component.
To change the baud rate, remove R9 and add through-hole component R14 (see Table 1).
04-537 9188
