Providing high bandwidth and Power for IP Surveillance Cameras: Tunnel Management in Norway
07/11/2018
Distributed network control architectures are used for Tunnel Management Systems to provide traffic guidance, CCTV, fire alarm, and ventilating systems while collecting several sensor data, such as vehicle detectors, VoIP emergency phones, visibility, and other sensors. Compact and
The Challenge
Prior to the new Tunnel’s opening in Norway, all of the necessary safety measures and equipment check needed to be completed. It was required that
The Solution
The System Integrator (SI) in Norway chose Advantech’s industrial switch EKI-7710E-2CPI as its interface includes eight 10/100 RJ-45 and supports IEEE 802.3
The flexible network topology, as shown below, supports multiple dual-ring networks from the control center. Each ring’s ID supports one tunnel and is flexible enough to be extended in the future.
- Long distances up to 120KM
- Immunity against Electromagnetic Interference (EMI)
- Immunity against Electro-Static Discharge (ESD) and Surges
The Features
The terminal block on the top of the device supports dual DC power 24/48VDC input. The Fault relay and fault LED indicate failed connection on power 1 / power 2 or link status on the SFP fiber ports. The fault relay is a switch where normal function is closed and
The Product
- EKI-7700 series with PoE+ technology
- The PoE+ features meet IEEE 802.3af /at standards for running electrical DC power over existing Category5 (or higher) copper cabling, while concurrently supporting the Ethernet data stream.
- To prevent damage to connected equipment, the
detected circuit will only provide as much power as the equipment actually draws. 8 x IEEE 802.3af /at PoE Fast Ethernet ports + 2 x Gigabit Copper/SFP combo ports - DIN rail and wall mountable
- Wide-range operating temperature (-40 to +75°C) DC power
- Accepts any MSA-compliant SFP
- Dual 24~48 VDC power input and 1 relay output
- Security: 802.1x (Port-Based, MD5/TLS/TTLS/PEAP Encryption), RADIUS
- Management: SNMP v1/v2c/v3, WEB, Telnet, Console, Standard MIB, Private MIB
- Redundancy: Gigabit X-Ring Pro (ultra-high speed recovery time < 20ms), MSTP/RSTP/STP (802.1S/1w/1D)The Benefits
- Flexible topology and easy to extend in the future• SFP socket for Easy and Flexible Fiber Expansion
- Provides PoE+ for all copper ports
- Any node supports fast redundancy
- Supports wide voltage 24VDC boost up to 52VDC
IXM function enables fast deployment- Dual image
- Fiber and Power alarm
Edited by
Kuei Lang 郎閣揆
Advantech IIoT Intelligent Connectivity Product Marketing
kuei.lang@advantech.com.tw
Jimmy Cooper
