SQR-SD5M 64GB DDR5 7200 Memory Boosts Semiconductor AOI Inspection Performance
2026/9/28
As semiconductor manufacturing grows more sophisticated, Automated Optical Inspection (AOI) equipment must process larger, more complex image datasets to detect defects with high accuracy. High-resolution multi-camera capture, real-time image processing, and AI-based inspection algorithms place heavy demands on system memory and computing performance.
Customer Pain Points
AOI systems must capture high-resolution images from multiple cameras while running real-time preprocessing, defect detection, and classification algorithms. Limited memory capacity can cause processing delays or unplanned downtime, while semiconductor fabs require sustained, reliable operation to avoid yield loss and production delays.
Project Description
As wafer sizes and process complexity increase, a single 32GB DIMM can no longer meet the memory demands of real-time image reconstruction and AI-based inspection. This project integrates the SQR-SD5M DDR5 7200 64GB CSODIMM to deliver the capacity needed for simultaneous multi-camera image processing, built with original-grade Hynix tier-one ICs to ensure long-term reliability for continuous production use.
Solutions
The SQR-SD5M DDR5 7200 64GB CSODIMM combines high capacity, original-grade Hynix tier-one ICs, fixed BOM management, and 30µ” PCB Thickened Gold Finger gold-finger design—helping AOI equipment manufacturers sustain high-performance computing while minimizing long-term supply and requalification risks.
Key Solution Highlights
- 64GB high capacity per DIMM for multi-camera, high-resolution image processing
- Original-grade DDR5 7200 Hynix tier-one ICs for maximum compatibility and reliability
- 30µ” PCB Thickened Gold Finger for enhanced contact durability and reliability
- Built-in CKD (Client Clock Driver) enhances clock signal quality, ensuring stability and signal integrity for high-speed DDR5-7200 operation
Benefits
- Reliable performance during continuous 24/7 AOI operation, reducing downtime
- Stable memory performance for high-speed 7200MT/s image reconstruction
- Uninterrupted AOI operation, ensuring continuous inspection data output
