我的研華會員註冊
立即註冊,啟用您的會員服務!
Automobile Anti-Lock Brake Testing System
應用案例 10/08/2024
The braking system is crucial for driving safety, which is why brake components undergo extremely rigorous testing to ensure reliable performance in all conditions.
Airbag
Project Introduction
The braking system is crucial for driving safety, which is why brake components undergo extremely rigorous testing to ensure reliable performance in all conditions. Using advanced brake detection devices and precision measurement and sensing technologies, brake test platforms can evaluate brake systems for various vehicle types. The testing methods employ torque sensors and servo motors, while both analog and digital data acquisition cards are integrated with MIC-770 fanless embedded systems. The MIC-770 system seamlessly links real-time data with standard data, utilizing a PC-based structure for data acquisition, signal processing, industrial control, automation, database management, and computer monitoring techniques.
  • The high-performance, ruggedized industrial computer equipped with the latest 12th Gen Intel® Core™ CPU (formerly named: Alder lake) must withstand 8 hours of continuous operation without stopping in order to perform brake fatigue tests.
  • Compact and modular design of industrial computer system with 2 PCIe slots, supporting multiple PCIe expansion cards.
  • System hardware stability is essential because the brake safety system must satisfy strict national standards.
  • Multiple parameter batch sets for use under multiple conditions.
  • MIC-770 V3: Compact Fanless System with 12th Gen Intel® Core™ CPU Socket (LGA 1151)
  • MIC-75M20: 2-slot expansion i-Module with 1 PCIe x16, 1 PCIe x4
  • PCIE-1884: 32-bit, 4-ch Encoder/Counter with Preload Position Compare FIFO PCIE Card
  • PCIE-1812: 250 kS/s, 16-bit, 8-ch, Simultaneous Sampling, Multifunction PCIE Card
This testing system is based on the high-performance fanless modular IPC MIC-770 V3 with a MIC-75M20 2-slot expansion i-Module, providing flexible embedded system to examine the brake capacity efficiency by measuring the brake pedal’s stepping stroke and the corresponding brake force. The 250 KS/s simultaneously high-speed sampling and the 16-bit ultra-high resolution can enable the PCIE-1812 to accurately capture the brake resistance of the tires at same time, while the PCIE-1884 encoder card can synchronously record the stepping stroke of the brake pedal. In conjunction, they plot an intensity diagram that illustrates the amount of force applied to the tire for each unit of stepping stroke applied to the brake pedal, and thereby analyze braking system actuation efficiency.
The braking system is essential for driving safety, necessitating rigorous testing to ensure reliability. Advanced brake detection devices and precision measurement technologies evaluate brake systems across vehicle types. The MIC-770 fanless embedded system, integrated with analog and digital data acquisition cards, links real-time data with standard data for comprehensive analysis. The system's high-performance modular IPC, with PCIE-1812’s 250 KS/s sampling rate and 16-bit resolution, accurately captures brake resistance and pedal stroke, while the PCIE-1884 encoder card records the brake pedal's movement. This setup creates an intensity diagram to analyze braking efficiency, enhancing overall vehicle safety.
聯絡研華
