What is Edge Computing? How it Works, Benefits, and Uses
Industry Focus 09/26/2024
Edge computing brings the power of data processing and storage closer to the source, minimizing delays and maximizing efficiency in connected environments.
As demand for faster data processing grows, traditional cloud computing faces limitations in latency and bandwidth. Edge computing emerges as a solution, processing data closer to the source, enhancing efficiency, and meeting the need for real-time responsiveness in modern applications.
Edge Computing Key takeaways
  • Edge computing processes data close to its source, reducing latency and easing bandwidth demands compared to sending everything to the cloud.
  • It is not the same as Edge AI — many edge workloads (data collection, filtering, protocol conversion, rule-based control) run without any AI.
  • Edge AI adds machine learning and AI inference at the edge for pattern recognition and predictive tasks; managing many AI-enabled edge devices typically requires a dedicated Edge AI management platform.
  • Core benefits include lower latency, improved data security, reduced bandwidth costs, and reliable operation even with limited connectivity.
  • Common use cases span manufacturing, oil & gas, energy, autonomous vehicles, healthcare, and traffic management.
Edge computing is a distributed computing paradigm that brings data processing and storage closer to the location where data is generated, often at the "edge" of the network. This proximity to the data source allows for faster processing, reduced latency, and real-time decision-making, which is critical for applications requiring immediate responses, such as IoT devices and autonomous vehicles​ or edge computers.
The primary advantage of edge computing over traditional cloud computing models is its ability to reduce latency significantly. By processing data closer to the source, edge computing minimizes the delay between data generation and processing, making it ideal for real-time applications​.
Key Components of Edge Computing
Edge Devices: These are the data-generating devices, such as sensors, smartphones, or IoT devices, that operate at the network edge. They perform initial data processing locally, reducing the amount of data that needs to be sent to central servers.
Edge Servers: These act as intermediaries, processing data from multiple edge devices. They are strategically placed closer to the network edge, enabling efficient local data processing and reducing the load on central servers.
Connectivity/Network: This refers to the communication infrastructure that links edge devices and servers. Reliable, high-speed connections are essential for the seamless operation of edge computing, ensuring data is transmitted quickly and securely across the network​.
How Does Edge Computing Work?
In an edge computing system, data flows through several key stages, starting from generation to processing, and finally, communication and actionable insights.
Data Generation at Edge Devices
At the network edge, various devices like sensors in factories, cameras in smart cities, or IoT devices in healthcare settings continuously gather data. This data includes diverse inputs such as temperature readings, video feeds, or patient vitals.
Local Processing on Edge Servers
Once collected, this data is processed locally on edge servers or gateways. Here, the data undergoes filtering, analysis, and potentially complex computations such as running AI models. This local processing optimizes the data stream by retaining only relevant information while discarding redundant or less critical data. This step reduces data load and enhances efficiency.
Communication with Cloud/Data Centers
After local processing, refined data can be securely transmitted to cloud data centers or centralized data repositories. This transmission is selective, focusing on critical information that requires long-term storage or further extensive analysis. By minimizing bandwidth usage, this approach ensures that only essential data is sent to the cloud, optimizing network resources.
Actionable Insights and Real-time Decision-Making
The processed data at the edge enables immediate actions and real-time insights. For instance, in a manufacturing setting, analyzed sensor data might detect impending machine failures, prompting timely maintenance actions directly at the edge. This capability is crucial for applications demanding rapid decision-making, such as autonomous vehicles or industrial automation, where delays caused by cloud communication could be critical.
How Edge Computing Relates to Edge AI and AI Inference
Edge computing and edge AI are often used interchangeably, but they represent different layers of capability. Understanding the distinction helps businesses choose the right level of technology for their needs — and avoid over-investing in AI infrastructure they don't actually require.
Edge Computing: The Foundational Layer
Edge computing is the broader, umbrella concept. Its core function is moving data processing and computation physically closer to where data is generated, rather than sending everything to a centralized cloud or data center. Many edge computing scenarios never involve AI at all — for example, collecting sensor readings, filtering out noise or redundant data, converting between industrial protocols (such as Modbus to MQTT), running rule-based analytics (if-this-then-that logic), or performing local control of machinery. These tasks rely on deterministic logic, not machine learning, and can run efficiently on standard edge hardware.
Edge AI and AI Inference: The Intelligence Layer
When a business's needs go beyond fixed rules — for instance, recognizing patterns in sensor data, detecting subtle anomalies, or classifying images — edge computing alone is no longer sufficient. This is where Edge AI comes in. Edge AI applies machine learning models directly on edge devices or edge servers, enabling AI inference (the process of running a trained model against new, real-world data) to happen locally, without waiting on a round trip to the cloud. This is essential for applications like defect detection on a production line or real-time object recognition in video streams, where both speed and data locality matter.
Edge AI Management: Scaling Intelligence Across the Fleet
As organizations deploy AI models across dozens or hundreds of edge devices, a further layer becomes necessary: Edge AI management platforms. These platforms handle model deployment and updates, performance monitoring, and lifecycle management across a distributed fleet of AI-enabled edge devices — turning individual edge AI deployments into a scalable, centrally governed system.
In short: edge computing is the infrastructure and processing paradigm, edge AI is what happens when intelligence is added to that infrastructure, and edge AI management is what makes that intelligence operable at scale.
Benefits of Edge Computing
Edge computing offers several key benefits that make it a valuable technology for businesses across various industries. Here's a detailed look at these advantages:
Decreased Latency
By processing data closer to the source, edge computing eliminates the need to send large amounts of data to centralized cloud servers for processing. This is the most significant benefit of edge computing. This localized data processing enables faster response times, which is critical for applications requiring real-time data analysis, such as autonomous vehicles or industrial automation systems.
Improved Data Security
Edge computing enhances data security by keeping data closer to its source, thereby reducing the need to transmit sensitive information across potentially vulnerable networks. By processing and storing data locally, the risk of interception during transmission is minimized. This localized approach also helps organizations comply with data privacy regulations by ensuring that data does not leave its jurisdiction.
Enhanced Bandwidth and Increased Productivity
Edge computing reduces network bandwidth usage by processing data locally, minimizing the amount that needs to be transmitted. This optimization allows businesses to handle larger data volumes more efficiently and reduces network congestion. Additionally, the reduced data transmission requirements free up network resources, leading to increased overall productivity, especially in environments with limited bandwidth.
Reduced Costs
Edge computing helps lower operational costs by minimizing the need for expensive cloud processing and storage. Since only essential data is sent to the cloud for further analysis, companies save on data transfer and storage costs. Furthermore, by reducing reliance on centralized cloud services, businesses can decrease their dependency on costly cloud infrastructure, leading to significant cost savings.
Real-Time Remote Data Collection
Edge computing enables the real-time collection and analysis of data from remote or challenging environments. Whether it's monitoring equipment in remote oil fields or tracking environmental conditions in agriculture, edge computing ensures that data is processed and acted upon immediately, even in areas with limited connectivity. This real-time capability is crucial for making timely decisions and ensuring operational efficiency in remote locations.
Reliable Performance
Edge computing provides enhanced reliability by reducing the dependence on centralized data centers and cloud services. In the event of network disruptions or connectivity issues, edge devices can continue to operate and process data locally, ensuring continuous operation. This decentralization of data processing also mitigates the risk of a single point of failure, making systems more resilient and reliable.
Challenges of Edge Computing
While edge computing offers numerous advantages, it also comes with several challenges that need to be carefully managed. Here are some of the key drawbacks:
Security Concerns
Edge computing distributes data processing across numerous devices, which can increase the number of potential entry points for cyberattacks. These edge devices may be located in less secure environments, making them more vulnerable to physical tampering and cyber threats. To overcome these challenges, implementing robust encryption, regular security updates, and strict access controls is essential to safeguard the data processed at the edge.
Increased Hardware Management Complexity
Managing a dispersed network of edge devices introduces significant complexity. Each device may have unique maintenance, software updates, and security requirements, making centralized management difficult. Organizations can address this by adopting centralized management platforms that offer visibility and control over all edge devices, enabling consistent updates and monitoring.
Scalability Limitations
Scaling edge computing solutions can be challenging due to the varied and often resource-constrained nature of edge devices. These limitations can hinder the deployment of new services or the expansion of existing ones. Overcoming scalability issues requires designing flexible, modular systems that allow easy integration of new devices and the use of cloud resources when necessary.
Edge Computing Use Cases
Edge computing technology is being applied across various industries, revolutionizing how data is processed and utilized in real-time, close to its source. Industrial personal computers (IPCs) are essential in implementing these technology solutions, offering robust and reliable platforms that can operate in various demanding environments. Here are some key applications of edge computing in different sectors:
Manufacturing
In manufacturing, edge computing is pivotal for sensors and predictive maintenance, as well as defect inspection/quality control. By processing data locally, manufacturers can monitor equipment health in real-time, predict failures before they occur, and ensure product quality through automated optical inspection systems. This reduces downtime and enhances production efficiency.
Oil and Gas
The oil and gas industry benefits from edge computing through remote asset monitoring. Given the often remote and harsh environments of these operations, edge computing enables real-time monitoring and management of assets without relying on consistent cloud connectivity. This leads to better operational efficiency and safety.
Energy
In the energy sector, energy consumption management is optimized with IoT devices and edge computing. These technologies allow for real-time monitoring and adjustment of energy use, leading to more efficient operations and reduced costs.
Discover how Advantech is driving innovation through its partnership with Mirai Electronics, which is revolutionizing remote energy monitoring and management.
Autonomous Vehicles
Edge computing is crucial for autonomous vehicles, enabling real-time data processing for navigation and safety. By reducing latency, vehicles can make split-second decisions, enhancing safety and driving efficiency. Learn more about how Advantech’s MIC-7700Q High-Performance Platform supports these advancements.
Healthcare
In healthcare, edge computing is used in medical equipment for streaming images and sensors. By processing data on-site, such as the 3D CT Scan Image System, healthcare providers can achieve faster diagnostics and better patient outcomes to level up the quality of the healthcare industry.
Traffic Management
Edge computing is enhancing traffic management by enabling real-time monitoring and improving safety. In China, with the removal of toll stations, overloaded vehicles pose greater risks. Advantech's UNO Embedded Computers provide the edge computing power needed for real-time processing, helping identify overloaded vehicles instantly, thus protecting roads and ensuring safety.
Edge Computing vs Cloud Computing
Cloud computing refers to the delivery of computing services such as servers, storage, databases, networking, software, and analytics over the internet ("the cloud"). This model allows users to access and store data on remote servers hosted by third-party providers rather than relying on local hardware. Users interact with these servers through the internet, sending data to be processed or retrieved as needed.
The main difference from edge computing is that cloud computing relies on centralized data centers, which can introduce latency as data travels back and forth from the user's device to these distant servers.
Feature
Edge Computing
Cloud Computing
Data Processing
Processed locally at the network's edge, near the data source
Processed in centralized data centers, far from the data source
Latency
Low latency, ideal for real-time applications
Higher latency due to distance from the data source
Scalability
Limited by local resources, more complex to scale
Highly scalable, resources can be scaled up/down easily
Cost
Higher initial setup cost, lower data transmission cost
Lower initial cost, ongoing subscription costs
Security
Enhanced security due to local processing
Centralized data can be a prime target for attacks
Suitable Use Cases
Real-time processing, IoT, autonomous vehicles
Large-scale data processing, global collaboration tools
Many organizations are looking for solutions that combine edge and cloud computing to capitalize on the strengths of both. This hybrid approach processes time-sensitive data at the edge while using the cloud for large-scale storage, analytics, and long-term processing, optimizing performance, cost, and flexibility.
For example, Advantech is a leading provider in this space and offers robust hardware and software that ensure seamless integration between edge and cloud environments, helping organizations maximize efficiency and security in data processing.
Edge Computing FAQ
Can edge computing work without an internet connection?
Yes. One of edge computing's defining advantages is its ability to operate independently of a constant internet connection. Because data is processed locally on edge devices or edge servers, critical functions — such as monitoring, local control, and immediate decision-making — continue even during network outages. Once connectivity is restored, selected data can sync back to the cloud for long-term storage or further analysis.
How is edge computing secured?
Edge computing security relies on a combination of measures applied at the device, network, and management levels: encrypting data both at rest and in transit, enforcing strict device authentication and access controls, applying regular firmware and software updates, and segmenting edge networks to limit the impact of a potential breach. Because edge devices are often deployed in physically accessible or remote locations, physical security measures — such as tamper-resistant enclosures — are also an important part of a complete security strategy.
When should a business choose edge computing?
Edge computing is the right fit when applications require real-time or near-real-time responses, operate in locations with limited or unreliable internet connectivity, generate large volumes of data that would be costly or impractical to transmit in full, or must keep sensitive data within a specific facility or jurisdiction for compliance reasons. Common examples include predictive maintenance on a factory floor, remote asset monitoring in oil and gas, and autonomous vehicle navigation.
How do companies manage edge computing at scale?
At scale, organizations typically rely on centralized management platforms that provide visibility and control over a large, distributed fleet of edge devices — covering remote monitoring, over-the-air software and firmware updates, and consistent configuration across sites. When AI models are part of the deployment, this often extends to a dedicated Edge AI management platform, which additionally handles model versioning, performance monitoring, and updates across all AI-enabled devices.
Advantech - Reliable Edge Computer Solutions
Edge computing processes data closer to its source, reducing latency, enhancing security, and improving real-time analysis. This technology is crucial for industries like manufacturing, healthcare, and smart cities that require immediate data processing. With the growing adoption of edge computing for IoT applications and its integration with AI and machine learning, its role in driving efficiency and innovation is set to expand. The global edge computing market is expected to grow rapidly, underscoring its significance in modern digital infrastructure.
Advantech stands at the forefront of edge computing services, offering robust and reliable edge computer solutions tailored to meet diverse industry needs. Their solutions are designed for durability and performance, providing seamless integration, enhanced security, and real-time data processing capabilities. With a strong focus on innovation, our edge computing services empower businesses to optimize operations and drive growth.
Explore Advantech’s comprehensive range of edge computer and edge services products and discover how their cutting-edge solutions can elevate your business now.
Explore Details
Liên hệ Advantech
