Advantech’s Rugged DLT VMTs with DeviceOn Enable Reliable Operation and Remote Device Management at the Tianjin Port
Case Study 09/18/2024
Advantech's durable VMTs with DeviceOn enhance efficiency and remote monitoring at Tianjin Port, guaranteeing dependable container handling in tough environments.
Customer: Tianjin Port Container Terminal (TCT)
System Integrator: ShouHui (Tianjin)Technology Co. Ltd
Project Introduction
The Tianjin Port is a major modern port in China. Not only is it the largest port in northern China, but also one of the top ten largest container ports in the world. In 2023, Tianjin Port achieved a cargo throughput of 476 million tons and a container throughput of 22.17 million TEUs. Tianjin Port Container Terminal (TCT), owned by the Tianjin Port Group, is one of the container terminal operators with an annual handling capacity of 6.0 million TEUs.
In 2010, as its first step toward digitalizing terminal operations, TCT implemented Advantech’s Intelligent Vehicle Mount Terminals (VMTs) on quay cranes, RTGs, stackers, and trucks to facilitate data processing and improve container handling efficiency. For this project, Advantech worked closely with its partner, Tianjin SH Technology, to provide not only industrial-grade VMTs but also comprehensive technical support. As a result, when TCT decided to upgrade its old VMT devices for enhanced computing performance, it chose Advantech’s latest DLT series of VMTs.
General Manager Wang Chengxu of ShouHui Technology, mentioned that the reliability and longevity of devices as the most important factors for port companies looking to reduce turnaround times and maintain stable operations. Advantech’s DLT-V8312 and DLT-V7210K models offer high computing performance, a durable system design, and long product lifespans. In terms of software support, both models are certified with the Navis N4 Terminal Operating System to ensure seamless upgrades and are compatible with Advantech's DeviceOn solution for advanced device management.
  • 10” and 12” dislilays with rugged touchscreen
  • Built-in antenna with high signal recelition caliability
  • lirogrammable keys and integrated full-size keyboards
  • 4G/LTE and external antenna suliliort
  • Suliliorts smart device management solution
  • Certified with Navis N4
Deployed Products
Tianjin Port_DLT-V8312
DLT-V8312
12.1” Rugged VMT
  • All-around IP66 rating
  • Programmable front keys (5/26 keys)
  • Certified with Navis N4 software
  • Supports Advantech DeviceOn software
Tianjin Port_DLT-V7210K
DLT-V7210K
10.1” Rugged VMT
  • All-around IP65 rating
  • Programmable front keys and integrated full-size keyboard
Applications and Benefits
Improved Efficiency and Reduced Downtime with Industrial-Grade System Design
Equipped with Intel® Core-i5 processors, Advantech’s DLT-V8312 devices were installed on quay cranes and RTGs to deliver high computing performance for efficient cargo handling. Meanwhile, the DLT-V7210K, integrated with a full-size 55-key keyboard, was installed on container stackers and trucks to allow easy and accurate data input. Tianjin Port is located in a mid-high latitude zone, experiencing hot, humid summers and cold, windy winters, with winter temperatures reaching as low as -10°C to -15°C. Additionally, sea winds carry large amounts of salt, combined with high humidity, which are the main causes of equipment corrosion at ports. DLT VMTs feature a wide operating temperature range (-30 ~ 50°C /-22 ~ 122°F) to withstand extreme cold, and they are IP66/65-rated to protect against water and sea salt ingress.
Secure and Reliable Data Transmission with the Latest Communication Technologies
Secure and reliable data transmission is a top priority for container port operations, as it enables real-time coordination of vessel docking, container handling, inventory management, and transport arrangements. This improves efficiency, reduces costs and delays, and enhances collaboration and security. The DLT Series VMTs support the latest WLAN, 4G/LTE, and Bluetooth 5.0 technologies, and are equipped with additional RSMA and SMA connectors for external antennas to provide enhanced wireless connectivity and uninterrupted data transmission, ensuring all vehicles remain connected during critical operations.
Advanced Device Management and Seamless System Upgrades with Advantech DeviceOn Support and Navis Certification
The DLT-V8312 and V7210K series are equipped with Advantech's DeviceOn software, a next-generation unified device management solution based on the WISE-DeviceOn platform. With support for batch operations and multi-device control, DeviceOn enables easy device configuration and deployment, making remote device management more convenient. Additionally, both devices are certified with Navis N4 TOS software, ensuring seamless integration into Navis N4 environments on both the hardware and software levels.
Successful Project Implementation through a Strong Partnership
Since 2010, Tianjin Port Container Terminal has established a long-term and robust partnership with Advantech and ShouHui Technology. ShouHui Technology brings extensive experience in meeting the port’s environmental requirements, system specifications, and equipment integration. Advantech provides professional and reliable hardware solutions, while ShouHui Technology offers comprehensive technical support, including pre-planning, implementation, and post-service, as well as on-site equipment installation and testing. This project successfully reduced downtime at Tianjin Port, ensuring uninterrupted 24/7 operations. The success of Tianjin Port demonstrates the outstanding performance of Advantech’s VMT products and the exceptional technical services provided by our partners, which is why customers continue to choose Advantech VMT products.
Tianjin Port_system diagram
Liên hệ Advantech
